A Dantes Peak style snorkel would get you cold air and top of being out of the dust.
You firstA Dantes Peak style snorkel would get you cold air and top of being out of the dust.
Working on it.You first
You need a snorkle with those big floaty tires?Working on it.
It may not be huge gains, but there is a reason the OEMs spend a ton of engineering time and money to get the factory intake setups pulling air through the fender, grille or hood but not open to the heat under the hood.I’m curious to see if you actually see a difference. I know they say cold air makes power and I know it does but in my experience it’s so minimal it’s not worth the price.
That’s fair. Did some quick and dirty. Figured at 100% VEOddly coincidental that this Hot Rod article popped up in my news feed. Way too much math for 5:45 am, but interesting read.
Hot Rod article
So two 4" ducts should be enough or that's two 6.5" ducts?Figured exactly how they did, needs 6.5”
Cold air for a hot running motor.You need a snorkle with those big floaty tires?
It’s all about the fresh air. There’s even a meme in the pig pen about fresh truck airYeah because I need to make my truck taller.
