And it continues build thread. Dead.. sent to the scrapyard
Well hope this fixes it.
25 bucks with Delco ignition module. Cap is still good as well
Drillmaster :haha: I have that same set -- for the twelve bucks or whatever, you can't go wrong.
-- A
-- A
They were on sale for 6.99. I bought a few. They work surprisingly well.
Anyways the new Dizzy did the trick. It runs now but I need to adjust the timing a little more. My timing indicator is so rusty I can't see where 0 degrees is. It runs but its running real rich, my o2 sensor may be bad or dirty. I ran it around the yard for about 30 minutes with no issues. If it stalled it fired right back up. Seems to miss every once in awhile.
Also this fixed my oil leak, stupid crappy ebay dizzy. See how much oil was on the old dizzy. There was about 1/8" of play in the shaft.
Also one of the mufflers fell off, sounds great, wish I could keep it that way.
Jess that bluetop is like my yellow top, I used a marine box to put mine in, it was like 12-15$ for the box.
Whoops forgot I only tack welded the spring perches on.
:popcorn::popcorn::doah::doah:
Was to giddy that I had it running real good today. Broke the tack welds and some other stuff. Gotta order some bushing kits, and perches from kert tomorrow.
I need to make a list so I don't forget about anything else. I can't believe I forgot about that. Pulled the shaft and engaged the front drove it back into the barn. I quit after that, sighted in my bow and went home to have a beer!
:haha::haha:
opps
I've never done that (probably cause I just started welding) but give it time.... :)
is the DS ok?
opps
is the DS ok?
Yeah the driveshaft is okay just a few dings in it.
I only tacked it together to make sure my pinion angle was matching the angle on the tcase which it was right on. The welds broke from the cast steel perches. Better to call kert and get some plane steel
Looks good, that was one of the best things I did to my truck in the rear after the shackle flip and soft springs. It was almost useless because of all the axle wrap but after the bar went in it was 100% eliminated. I think you'll be happy.
god thing you didnt have that done awhile back:rolleyes: You may not have found out about the spring perch tacks until you were on a trail in BFE.
looks good man:waytogo:
Yah can't wait to try it out. Hopefully it lives up to my expectations. I have 63's so it was a must! Doubler plust soft springs = axle wrap so I had to do it. Hopefully this weekend or next weekend I can go beat and really test it before I hit the trail on the 22nd.
Nice work on the traction bar Jess. :saweet:
Was there anyone there to have an hour long discussion with about it or did you just build it and go? :dunno:
I have the same one :waytogo:, I love it :bow: I think at last count I've burned 2 or 3 11lb rolls of wire through it.......and I just bought mine back in April this year :D (just before I built my K30)
Yup I am amazed how quickly I go through wire !!! Need to buy a big spool.
Whadya get done this weekend jess? If you say nuttin ima say your lyin.. You cant get a fancy new welder and not get anything did :D
