Same problem as mine. I went through lengths to try and fix. Checked adjustment of TV cable, changed fluid and filter, removed valve body, installed shift kit. No dice. I just dealt with it running in 3 speeds, keeping the gear selector in the "D" position. Then one day running around up in the hills, I ran it in 4 low(unusual for me at the time). On the ride back down the trans shifted to OD. All I can figure is that something was sticking and the shock applied while in 4 low Un - stuck it. This was over 6 years ago, the transmission is still running to this day currently turning 37's. Not saying it will fix yours but give it a try, couldn't hurt.
