On the left side down where that is, could it be one of the wires to the back up lights, via the reverse switch on the trans?
That's a good point...my backup lights don't work...where is the reverse switch on the transmission?
That is not factory in a 70 square body blazer and pickups. The wire for the fuel gauge should leave harness by the starter and run down the passenger side frame rail. It should be the ONLY wire that runs down the passenger side frame rail.
Actually that is factory, "sort of" for this year blazer. I kind of forgot how the wires are routed on the 73,74 since I rerouted mine ages ago. The loom goes from the intake valley, down the front of the motor, then goes along the oil pan. There should be a few studs instead of bolts along the pan rail so you secure the loom with clamps. I think the PO should have routed the harness under the fuel pump instead of to the side of it.Someone has definately been in there doing something for sure as i've NEVER seen any wire loom anywhere near the fuel pump area ever.
I don't know if your truck even has a reverse switch on the trans, but, it's a possibility.
I may have read your post wrong. is that wire on the driver side (left) or passenger side(right)?
What trans do you have? Make and model?
That should be the wire that goes to the fuel gauge. I couldn't tell from your earlier pics if it was hooked up.Well...there is a single wire that runs down the passenger rail...I think it is the light brown colored wire in this picture...but I swear the wire that was run to the gas float came out the drivers side rail...
Is your truck a manual?That's a good point...my backup lights don't work...where is the reverse switch on the transmission?
Manuals have the switch on the transmission.
Auto have the switch on column inside the cab.
Thinking ahead, your blazer was probably a manual at one time and someome swapped in an auto.
Here I have two different engine harness for a 73, 74. The top one has wires for A/C and the back up light switch for a manual. These are not for sale. I don't know how good of shape these are in.
Looks like just the underhood wiring for the engine.
American Auto wire has a replacement harness. From the catalog I downloaded, it is about $114 dollars just for the engine harness.Can I buy just that wiring somewhere? or do the rewiring kits only contain everything?
I may have missed something
what is working?
P/N 37482
what is working?
fuel
fuel gauge works
choke
No electric choke on 74
temp
The temp works but use a black wire. Factory is green.
oil
If he has gauges, it should be mechanical. Idiot light should take a blue wire.
tach?
Have not been covered
AC
Possible, it is green wire.
alt exciter
Possible, should be brown.
lights
different harness which runs on the other side of the motor. If it reaching by the starter, then the guy a big problem. Although I suspect the PO may have swapped a harness manual application the wire to the switch is green/light green.
Is the sparking from THIS wire or some other wire?
Is this wire constant hot, ign hot, or some kind of switched hot?
We never got to test it yet. We were just going by the color code.
never mind the color, just pull the shielding off and find where it goes, but this thread needs some serious clearing up, unless I missed that
I can't honestly say. Normally the stuff only goes one way, but for this harness, you have deal with the "eyelets" on the firewall junction block, alternator, and starter. That is where some people get into trouble.Do you know if there is a guide or something that tells you where eveything goes? Wiring problems scare me as far as fire and stuff...I want this done right.
