Well, I again refer you to this thread, number 13.
http://coloradok5.com/forums/showthread.php?t=281817&page=2
Look at the schematic of the connectors. You will see that on the left hand side, one is labeled engine and the other, front lp.
You can also see the shape of the two connectors.
One set of wires from one plug will go to the lights and the other plug will go to the engine.
The engine one has a tab at the bottom that fits into a socket of the lamp one.
The engine one is the one with the temp sending unit wire.
Its socket 35, and it will be in the same position on the firewall that it is on that schematic.
If the picture on that thread is clear enough, you should have all you need to find that wire.
If its not clear, let me know, and I can send you the jpg via E-mail.
Thank you! I see it now on the diagram....now let me see if I see it on the truck.
