Another green wire on those years was the one going to the anti-dieseling solenoid on the carb....that would only be hot with the key on..its fused too,so if it grounded out it would blow a fuse..
You can see if the green wire in question was for the water temp sender by turning on the key,and watching the gauge as you touch that wire to a ground,it should bury the needle--only ground it for a few seconds,as too long can harm the gauge..
