Well he had already mentioned that he had a coolant leak in the first post, near the number 8 cylinder area, i think thats why everybody is saying things about the heads and intake gaskets, if it's leaking out there, it could be leaving inside as well, thats all, no one has though mentioned anything about if he even has a fan shroud installed or not though. and he also mentioned he replaced everything on the cooling system which i would assume that includes the radiator, so that basically leaves the fan clutch, shroud or an internal leak. /forums/images/graemlins/dunno.gif
You basically sumed it up. Like I said I have replaced the whole cooling system including the radiator, fan clutch, stat, and hoses. I am running the stock shroud with it just slightly cut to clear from the body lift. It would run cooler at 35 in 3rd gear than 70 in 4th...so that would rule out airflow. Yesterday I got it at about 210 on the electric guage, popped the cap with it running and stuck a mechanical guage sending unit into my new 4 core radiator. The mech. guage read 192. So I guess it is the electrical guage. /forums/images/graemlins/doah.gif I guess the stock guage would fluctuate a lot if it was bad. /forums/images/graemlins/dunno.gif When I saw the coolant leaking I was almost certain that it had to be internal, that was just another problem in it's own, the guage is it I guess.
I guess I win the "dumbass of the month" award. /forums/images/graemlins/histerical.gif /forums/images/graemlins/doah.gif Oh well. /forums/images/graemlins/whistling.gif
