any trick for getting ... HELP more questions at botttom HELP!!!
Re: any trick for getting the tranny apart from the engine...
it shouldnt squish it. not sure if you took out the torque converter yet but they are pretty heavy so pe prepared. not super duper heavy but they have some weight to em. pretty much everything else was covered above. ijust wanted to toss that in there to avoid any suprises.
the torque converter is still attached to the tranny. how many pounds do you think it is? what is heavy to you, could be different from what I think is heavy, so just in case /forums/images/graemlins/thumb.gif
thanks!
its really not that bad. come to think about it weights alittle more then a bowling ball.
okay I will go take it off in a minute...
