Something that might help, is that obviously, marine gear drives have to be completely sealed as they're submerged in water (especially seawater). Not like our diffs, t-cases or even tranny's.
The oil has to keep from foaming and expanding too much or else it'll blow the rubber seals. It also has to keep the water away from the components.
I've seen a bunch of times someone will bring in their boat where they did an oil change on the cheap using automotive grade and blown seals out. Water gets in and makes a thick vanilla milkshake of the insides. The water stays in suspension and rusts the gears.
A pair of outdrive gears alone can cost anywhere from $300-$700 and that's not including the $80hr marine mechanic
You can run goat piss in a 465 and it'll be fine.
