It is the 12 and 41.
Be really hard to fit 83 teeth on a ring gear
Same, changed fluid in both tonight while on the lift. I miss my Toyotas where it's easy to count gear teeth. Lolbetter verify the front also . . .
Same date code? Or just the same 12 / 41 gear ratio?
So I got up a friend at East Coast Gear Supply. He said bigger number first. So 41 11 are 3.73s
Notice the little number is stamped first on a know set.
Why does the date code not make sense?
I thought you meant the date code on yoursSince his numbers are "12 41 11 83," if he reads "41 11" as the R&P numbers he's left with just "83" for the date code, with a random "12" on the side. Which makes no sense. "12/41 - 11/83" makes sense, at least to my eyes.
