G-Force8
I would go ahead and get a 14BFF rear axle with 4.10 gears in it and place want adds for the 8-lug parts off of a 3/4 ton corporate 10-bolt front axle. Actually, if you can find a 3/4 ton 10-bolt front end with 4.10 gears already in it, you're half done. These axles shouldn't go for more than $150, TOPS.
you will have to replace your wheels ,but you can get black rock crawler wheels from most of the major distributors for cheap (usually around $200 for 8 or 10" wide wheels).
I just picked up a 14BSF out of a 3/4 ton truck for $50. They are not quite as strong as the 14BFF ,but will handle 35's or 38's with ease in most terrain. That might be an option for you
Or, what I think may be your best bet, considering you are running 35" tires, would be to hunt down a 6-lug 9.5" 14BSF rear axle that was used on 88-98 Light Duty 3/4 ton Chevy trucks. It will be a relative bolt-in for your truck and be considerably stronger than your 10-bolt
