I don't see why you would bother.
The stock clutch isn't hard to use, and the cylinders are not prone to failure. Both 80's hydraulic setups I've pulled have had the original slave on them.
If you have to replace the stock one fine, but if it's not a direct bolt in and same cost or cheaper, (about $50@ napa IIRC) don't waste your time.
