Auto to mauual swap now no reverse lights
cegusman
3/4 ton status
Houston/Katy, Tx
Where is the wires that control the reverse lights? Are they conected to the nutral saffty switch. What colors should they be?
On top of the 465, drivers side near where it bolts to the bell housing is where the switch is.
Rene
It is plugged into a switch on top of the steering column just behind the firewall... park/neutral and backup lights both plug into it.
Go to the junk yard and get the cable that goes from this to the tranny (GM just extends them... plug in) along with the clutch / start safety switch (assuming you want to).
