pauly383
Daddy383
See thats what I thought , and posted , but it doesn't explain the 8 ring gear bolts .
Close, very close but where the cover bolts on, the flange is round where as mine has 'cut out' all around.big83chevy4x4 said:a quick look at randy's shows that the amc 20 could be had with 8 or 12 ring gear bolts.
i also found a ebay add for this
http://cgi.ebay.com/ebaymotors/Jeep-CJ-AMC-20-rear-axle-7-8-stick-dana-20-3-54-44-5_W0QQcmdZViewItemQQcategoryZ33731QQihZ009QQitemZ190109560321QQrdZ1QQsspagenameZWD1V
it looks to have the same rib ahead of the diff cover.
they may have changed the casting to get rid of the rib on later axles.![]()
They're cast in, not welded on. Def cast in.75k10chevy said:Yeah the PO did take it out of a chevelle and put it under the camaro. But who ever welded the perches on welded them on at the wrong angle so the pinion points slightly down. Oh well, at least its a good axle.
Moser and curries both make good axles for around $2000 but by the time I ship it and pay duties, it'll be £2000 which is about $4000 !4X4HIGH said:i would have Currie enterprises build you a 9" F*rd axle for that camaro. A 10 bolt axle has a very weak carrier and the 12 bolt is only marginally stronger. The Ford 9" is a very strong axle and easy to get all kinds of aftermarket parts for and even a rear disc set up.
southernspeed said:but it just bugs me as to what it is!
dyeager535 said:Oh, well that's easy to answer now. It's a spare part.![]()
Damn....thought I recognised it!
