Axle wrap right?
nmxhustla
Motor Tuh
New Mexico
Got a k5 with a 4inch suspension lift and 454 with pretty aggressive shifting transmission. Also a locker. I hear the wheels chirp when I turn almost anytime I turn it'll shift mid turn and bark a tire. Anyways I need an excuse to buy the DIY4X anti wrap kit. Thoughts?
Axle wrap and/or less than completely tight can break the pins.
upgrade to a grd 8 bolt and round the head . then have a flat machined in the wedge to let the pin sit correctly and NOT bend the pin . then get some center pin spacers or drill threads out of a 3/8" nut and round it also and add it in to give the pin more height and stick out correctly from the machined in flat . ALL this is from cheep shims not machined correctly and to short a center pin .
option #2 and better is new HD spring perches like diy4x or ruffstuff or offroad design and others sell and dial in your pinion angle and ditch the stupid shim .
I've got a Yukon grizzly locker and it will bark the tires in corners. I had to learn how to drive with it and generally coast through a turn, off the throttle.
Switching from 35's to 37's also seemed to help, possibly the added weight and rolling resistance.
Here we go, that's a solid reason to go to 37s I like it
option #2 and better is new HD spring perches like diy4x or ruffstuff or offroad design and others sell and dial in your pinion angle and ditch the stupid shim.
I'll have to look into that. Option 2 isn't very likely but my pinion angle is good. Got the t case lowering spacers and then I have the shims it's right where it should be if not very close.
I wouldn't be attributing this to axle wrap unless your putting the coals to it.... straight, or turn.. i'm guessing no blocks, which makes it even more unlikely..
chirping while turning is usually a locker issue.. which one?
my guess is the center pin is unrelated.. and possibly was magnifying a locker chirp...
I have a Yukon grizzly locker also the things been regeared to 456s to im thinking the torque is causing this. I put the coals to this thing almost every day and I also offroad it quite a bit I just assume the lift the tires and the leaf springs combined with the locker and the aggressive shifts is causing this
Them t-case drop kits kill the frt shaft angles / frame flange also . Your better off doing a c/v shaft and set the pinion angle for the rear .
And getting new ubolts always jump up to 5/8" over stock 9/16" rod for the ubolts . You get a LOT more clamping power and less axle walking issues.
Interesting I did a spacer for thr front shaft so it would not have issues but it worth looking into.
axle wrap will generally cause wheel hop, not a chirp per se... i would repair the spring pack properly and see what it does.. you can always give Kert money after.. ;)
Think about it . Your ANGLING down the rear of the case cause the engine is in the stock spot still . This in turn points UP the front output flange .
Lots of the info i give is from first hand real world with these trucks . And also the rest of it i have learned from the members here !
If the lockers jacked up its got a lifetime warranty so that's not a huge deal, we shall see what comes of this
This is actually wrong tho, my lowering kit doesn't lower just the rear it has spacers for all 4 points that mount the tcase to the truck the whole thing is just a bit lower not just the ass end of it
I agree w Ryoken here. The chirping is likely related to a locker, not a limited slip, or factory G80 locking diff., but a true locker. I have the wraptor system on my truck and its pretty awesome. I never get wheel hop w my BBC/T400/4.56’s and 40’s.
Does it lower the engine too?
think about it, just lowering the t/c will make the drivetrain tilt to the back, which would raise then front output.
Oh okay I see what you mean. I was like hold up I didn't like Carolina squat my tcase or some shit haha
