Barnes has good stuff too. https://barnes4wd.com/products/anti-wrap-leaf-spring-perch-pair-dana-70-and-gm-14-bolt
Sold out though?
Sold out though?
For some reason I was having some trouble finding what I needed but DIY4x is who I went with.I would say DIY4X or ORD or RuffStuff
I’ve been eying their stuff too.Barnes has good stuff too. https://barnes4wd.com/products/anti-wrap-leaf-spring-perch-pair-dana-70-and-gm-14-bolt
Sold out though?
Yeah I’m not using the qjet im using the edelbrock avs2so fyi the poncho q jets are tiny bit different than chevy. It'll work but linkages, non electric choke, fuel inlets are just a little different.
I have a qjet I could use. Probably needs rebuilt though. My pops found a couple out on car mountain off some RV’s that we’re getting junked.miss read the post. I am with your buddy on carb choice
Yeah I am putting new tierod and ends on.Tie rod ends should be the only thing left
If your are calling a Dana 60 a ball joint eliminator then yes. Otherwise just put good ball joints in it. For no more than you’ve said you plan on doing with it they are fine.Ball joint eliminators yay or nay?
Think I’ll go with moog since the spicer are not greasableIf your are calling a Dana 60 a ball joint eliminator then yes. Otherwise just put good ball joints in it. For no more than you’ve said you plan on doing with it they are fine.
I’ve got close to 20 years bearing on two different Dana 44 front axles and the only time I had to replace a ball joint is due to a u-joint taking out the bottom of one when it grenaded.
