No ring and pinion shims laying around?So obviously I burned $75 on shims lol and I can’t continue until they show up.
Nope when I moved here I got rid of a lot of stuff.No ring and pinion shims laying around?
My parts wont be here till sundayLove it when I get the parts I need for the weekend. Torque king for the win that was economy shipping too. I went ahead and ordered the main shaft shim kit at the same time. View attachment 491493
the manual did not show the direction of the reverse hub well but I was looking at my pics before tear down and realized it was reversed. Won’t be making that mistake again. It’s in and I actually got the bearing to seat better on the main shaft could shim it a little more and still got .003 end play. Pic of sketchy press shenanigans.
I think I have the tool you needed.I ended up using the old 5th gear nut and the old 5th gear to press on the new one using the 5th gear nut threads. Very carefully. After I got it pressed on I then used 1/2 a bottle of redloctite and sent it home with the impact and then used my body weight to make sure it was between 250-350 ft lbs. I would hate to be the guy who has to take this off in the future and I really hope it ain’t me lol View attachment 491626
Ended up making the tool.
This is the tool I needed. I have the other one too but during pressing on the 5th gear I was using it and the teeth just wore away on it. So I had this socket and lengthened it to clear the shaft and it worked perfect.I think I have the tool you needed.
It's a half a moon with a square tooth at the tip.
