Good call. The steering arm can be a pain to get off. It has split cone washers under the arm. There is a trick to removing it though. Make sure to torque the nuts on the steering arm correctly since it sounds like you already removed them.
To remove the drag link, sometimes if you give the steering arm a good whack on the side where the drag link connects it'll come apart.
