I want to!
I can pull just over a 100 amp load with everything on. I only have a 105 amp alternator. I ahve had to repair the factory battery mount four times now and have used it very little at the cabin. The other battery tray I made from factory specs and installed it on the driver's side. I have installed 2 efans by relays, the first of switch plates by relay, and the rear work lights by relay. These 5 relays are mounted on the battery tray that I built under the hood and I am running out of room for electrical relay mounting too. If I remove the batteries from the front to the rear then I have room under the hood for the relays and switching equipment and housings for all this type of equipment. Why 4 batteries, well, the group 78 batteries are better utilized for the starting system, i.e. they have a better cca rating and less of a rc rating. The group 31 are the exact opposite, they are better rc rating and less cca rating, so following that ideaology I am using the group 78s for the starting system headlights, control systems, etc, etc, and the group 31 for aux systems, radio, amps, e fams, ac blower motors, (the front blower motor pulls 18 amps on high, the rear ac pulls 22 amps on high and yes both of these motors are new and tested to oem standards) Right there I have a 40 amp draw. Not including the smaller e fan (17 amps) and the larger e fan (18 amps). That's 35 amps. Together that's 75 amps, not including the computer to run 3.5 amps, the radio 1.7 amps, amps 2.0 amps. Now think about rolling down a window, or even worse rolling down 4 windows at once, What do you think happens at cruise speed, well not much but at idle in stop and go traffic you have a noticable difference.
I don't like to run more then a 10% of a batteries capacity, I have the room in this truck to do it how I would like to, so I am. Granted there are still alot of questions floating through my head, but if I try and add all the equipment that I want to, and I stay with only the two batteries then I should just put in a standing order with my interstate dealer of delievering a new battery every 6 months to me as long as I have this truck in this use.
I have changed my initial thoughts of a hydraulic winch, I am now thinking of an electric winch (12,5k on the front, 8k on the rear) that as well has made me think that I need to really take a closer look at my electrical demands. I really don't want to turn the ac off just to pull someone out of a ditch! lol
I have spent the past few months talking with my wife about purchasing a new 'cabin capable' truck. I have spent a few afternoons at some custom truck manufacturers talking specs, for the money I would spend the capabilitieswould not be what they say it would do. Then on top of having to return it for warranty issues. It just doesn't make sense to me to spend A LOT of money on a vehicle that I would use 'occasionally', that's just a waste of resources. Plus, I like the older trucks, they aren't made to this style of workmanship now, and likely will never be again.
I will have, with the group 78 batteries, 1600 cca at 0 degrees, 2000 ca at 32 degrees. 170 minute reserve capacity with 25 amp load. On the group 31 batteries, I will have 1460 cca at 0 degrees, 1800 ca at 32 degrees, 380 minute reserve capacity with a 25 amp load. That's not bad figuring that I won't have a generator making noise and if I leave a light on all night then I can come out in the morning and hit the emergenacy self jump start switch and be off and running. Plus I'm not spending 60g on a new truck, that's a lot more money I can spend on a motor!!!
Granted there are still a lot of things that need to be worked through and figured out.
All input is welcome!!!
