BB '14 Yard Sale Thread
Jason4x4
Chandler, AZ
I'll start, I got a TBI 454, bought a parts truck, and this is under the hood, fired right up, it is missing the bracket that holds the power steering pump, and the egr valve is off for some reason, But I have it.
The block is Pink, the valve covers and oil pan are purple, so I would assume it was rebuilt at some point, but it is unknown.
It is out of an '87, so it has the carb intake with the adapter, and also a tbi spacer.
$700 delivered to Moab, if paid before, complete engine, the accessories minus p/s bracket, radiator, wiring and all tbi stuff.
:D:eek1::doah:
I also have everything else at this moment, I can bring doors/fenders/ misc if paid.
http://phoenix.craigslist.org/evl/pts/4501127527.html
Blazer Bash Yard Sale: Axle, Tranny, and T-case Parts
Here are some Chevy axle, tranny, and T-case parts that I would like to get ride of. All of these are used unless otherwise noted. Prices are delivered to Moab for Blazer Bash.
SOLD Dana 60/Spicer 30-spline hubs - $20.00
SOLD Dana 60/Spicer 30-spline stub shafts - $20.00
Dana 60 spider gears - $20.00
Dana 44 shafts and stub shaft w/u-joint (all stock) - $35.00
12-bolt shafts:
SOLD Stock (top) with 7/16" studs - $30.00
SOLD CrMo (bottom) (Superior?) with 1/2" studs - $40.00 (never installed, carried as spares)
SOLD - Balistic Fab Dana 60, long, driver side, springless, 3/4 ton TRE, high steer arm (Part #HSP-613-1): installed/mocked-up, but not driven - $35.00
NP203 t-case, 27-spline input, figure 8 bolt pattern - $75.00
NP205 shift rails - $40.00
NP203 27-spline input gear - $10.00
SM-465 32-spline, long, output shaft - $10.00
I can bring an NP241 passenger drop with JB conversion SYE. $400
I'm sure I have some other parts I need to get rid of too.
I have a 32 spline NP203 $100
And a 27 spline NP205 $75
I forgot to mention, this has a 32 spline input on it, but I have a 27 spline input as well as 90% of a second 241 that will go with this. I cracked a case half, so everything else is in a box. I've also got a variety of yokes that you could have your pick from. 1310 CV yokes, Saginaw CV yokes, 1350 non-cv yokes.
Now would be a good time to post that I will have a doubler for sale as well. 27 spline or 32 spline 203 input gear, figure 8 or round 6 bolt (one bolt slightly offset) housing.
I haven't decided on a price so I'm open for offers. I just need to keep the 205 as I'll end up putting a Magnum in front of it.
