I was told the junk in trunk crowd prefers a little wider seat tho
I resemble that remark.
Glad things worked out !
@Blazooki how are you liking the RZR seats after getting some seat time in them?
Appreciated, being 6'6 and 300 I'll probably pass on them then thank you!
yeah, thats prob a good call...Didn't realize you were so tiny.. pretty sure you couldnt fit in Ned with no seats
Wow, that was fast!Had some carnage on Friday at the Wall on Steel Bender. The rear drive shaft decided to become two pieces
Here is a photo of @ktmoutfront welding it so Poco Loco could get off the trail
While checking over Poco Loco for other damage, discovered that a c-clip for an axle joint was backing out. Turns out that another was already gone. I used the Tom Wood's certificate from the raffle to get a new drive shaft and also ordered CrMo inner axle shafts, new u-joints, and full circle clips from ORD/Yukon.
Spend Friday night 9/15 and Saturday 9/16 putting in the new parts. Poco Loco is all back together and ready for our next adventure in mid-October at Chile Challenge in southern New Mexico![]()
Talked to Steven at ORD on Monday and ordered the axle parts. Called Tom Wood's on Tuesday and ordered the drive shaft. UPS delivered everything to my house Friday - no expedited shipping!Wow, that was fast!
Only Carnage here was my back. Worst Pain I've ever had, and Nasty Muscle Spasms
So far, in order,
Friday- Chiropractor- Adjustment
Friday- Dr Office- Muscle relaxers, Hydrocodone
Sunday- E.R.- Steroid Shot, Ibuprofen 800, Steroid pills
Monday- Chiropractor- Adjustment
Wednesday- Chiropractor- adjustment
Thursday- Dr Office- More Pain pills, x-Rays
Have another DR visit tomorrow to see if xrays show anything, or MRI is needed.
Damn dude, what brought this on?
Steel Bender, changed an AC Delco fuel pump which only had some 200 miles on it. Not a big deal with access to the fuel pump through the bed, but still... it was new. Then there was "Cracked on the Way Back". 'Mojo' had a super flex joint on the transfer case side of the front, but decided to get rid of that because I did't like the vibration. So sent it back and they re-built it with a CV. Installed 2 days before BB, it seemed a little long when I put it on, but BB wouldn't wait. My bad. But did do flex tests, seemed good, but apparently not enough because when both tires came off a 20" or so ledge straight on, the driveshaft pushed back and cracked the tranny case. Very sad moment. Very very sad. Somehow #s mixed up and the shaft was rebuilt an inch long and neither Shawn at Tom Woods' nor I will ever figure how, but they offered to "share the pain" which was very generous on their part. I would never buy another brand. Can't thank @AgDieseler enough for the tow out, we know that sucked - we were probably some 3 1/2 very hard miles from the lot. Unfortunately, there was no armstrong steering over/through some obstacles, so had to start the motor several times, which finished off the tranny. Sorry for the lengthy post but if it saves someone else... but it's almost mended and will be even better than it was. -Matt
