BB2020 yard sale
Bent77
I am CK5
Nunya
Post your junk for sale/trade at BB 2020
HEI curve kit $5
Short chrome SBC valve covers $10
Random tie downs for valve covers, used ARP head bolts, stud girdles and poly locks $30 for all
More VC tie downs $5
Crane solid lifter 546/564 lift 250/260 duration @.050 cam with lifters, chain, thrust button $50
Th350 to NP203 adapter plate $10
2 piece rear driveshaft for 4” lift and long bed from 465/205 combo 1350 joints, with midship bearing $50
Moroso electric water pump drive kit (external belt style) $10
passenger side saddle tank w/ brackets for K10 - free
Any of this stuff also available to ship if someone wants to pay the ride
I'll confirm the following once it's all off the truck, get it inspected and cleaned up, but this can all go to Moab. I don't need to get rich, but I do need to recoup some dollars.
  • My full ORD custom suspension - it's settled into a very flexible 6" spring, and would be a one shot move to a max quality leaf suspension (sold to @fourwheelerjeff)
    • Front 48.5" and rear 52.5" 10 leaf packs (I'll pop in new center pins)
    • Rear 2.5" flip
    • Rear 6" super shackle
    • I'll load all this up with a set of new kevlar bushings
    • DIY4X front spring plates
    • Front bump extensions
    • I’ll try to keep the rear extensions intact, but they have to be cut off
  • 14" Bilstein 7100s with remote reservoirs (sold to @fourwheelerjeff)
    • front 347/70, with trimmed ford towers
    • rear 360/80, and the custom bolt-on-ish mounts
  • Barnes 4WD diff covers (sold to @Chevman88)
    • Front 60 with ram mount
    • Rear 13 bolt (you trim the bottom hole off the 14FF)
  • My current 14FF, which has 4.88s and a Detroit and very large drums. I’m replacing with a newer axle.
Again, I'll keep this post updated as parts come off the truck.
David
I'll confirm the following once it's all off the truck, get it inspected and cleaned up and add prices and photos, but this can all go to Moab. I don't need to get rich, but I do need to recoup some dollars.
    • Rear 2.5" flip
  • Maybe: my current 14FF, which has 4.88s and a Detroit and very large drums
David
I may be interested in both diff covers if I don't replace mine prior to BB.
Well, I’ll have these off and replaced before we get to July, and could ship them. Turns out, I have the perfect box.
David
In
    • Rear 2.5" flip
David
Interested in your shocks and possibly rear mounts if I can see what you have and maybe modify for a blazer.
Will you have a Burb left?
It will be there, but just trimmed out a bit differently.
The suspension and diff covers are set to go to new forever homes (thanks, @fourwheelerjeff and @Chevman88). I'm headed to the salvage yard today with my dad to look at a new-gen 14 bolt, so it's looking more likely that mine will end up being available.
David
David
So it will be lighter?
This is a 27 spline, shifter and cross member included. Like to get something for it in gas money if I have to haul it. It’s free it I don’t have to pick it up
‘84 K5 power tailgate and rear seat could make the trip if somone wants. Probably let go real cheap.
14 BFF Powertrax rear locker (new)
1 inch body lift (SOLD)
manual K5 tailgate with glass
tan carpet lower door panels
Make offers and shipping is available if buyer pays for the ride.
1 inch body lift
is that rear locker for a 10 bolt, 12 bolt, 14SF or 14FF?
