BBC Headers - Who's Got What?? UPDATE w/shortys!
If only they could. The gray coating I have is rough, like the CARC paint on a CUCV if you ever felt it. The silver finish is smooth and glossy so I doubt it would ever look right if they did. :crazy:
so, they may look galvanized...function over form ..you'd have two layers of ceramic coat, you may could hold the header while its running.. you'd never burn a sparkplug boot or wire,..no starter heat satration.....+then cooler intake charge=more hp/tq.....sorry its the addict in me...more is better sorry:) if they can double coat it, i'd take it no matter the looks...
Isn't that the second time you've had problems with the color?:confused::doah:
Yep. :doah:
When they were ready the first time, they were supposed to be gray but they were actually silver (chrome-ish). When I told her there was a mistake she offered to fix it and also not charge the additional amount for a color (because of their error). Now I get them and the gray looks like baked poo so they're going to strip them and go back to the silver I should have settled for the first time. :doah:x10
Did you find headers?
Yes, see post #19 - I bought some Sanderson shorty headers and they fit like a glove (no mods, no frame trimming, nothing). Here are a couple of pics -
Sanderson part # bb8
* Primary Tube Diameter : 1-7/8"
* Collector Diameter : 3"
* 16-Gauge Primary and Collector Tube Thickness
* 3/8" Thick Flange
* Patented Flange Design Requires NO Gaskets
Gtotomm,
Check out my build thread for a 2" /3.5" collector solution.
I ended up buying a set of Hooker headers, and they weren't even that expensive.... Part numbers are in my thread ( look around post 1000 where I show the painted BBC and accessory pics)
:usaflag:
Frustrating, cant get the pics, not a paid member i guess? what is the part # of the hooker headers? Thanks guys.
Really? Greg uses photobucket for all his pic's so they're remote linked and viewable by all. I logged out and was able to see the pics as a "guest" here.
Click the link in my previous reply.
As an unpaid member here the only pics that you won't be able to see are attached pics.
Rene
Added the P/N to my thread.....guess I forgot to put that originally.
P/N: 2455HKR
:usaflag:
I bought the $100 dollar Jegs headers and they fit pretty well with a little messaging
