Before i bolt in the 60 what else should i know....
84CUCV
3/4 ton status
NJ for now
Going with a 4" tc lift. Anything that can help me along would be great. thanks
Umm, lets see. Dana 60 use the same banjo bolts as 10 bolts, You will get about 3/4 of an inch lift from the axle alone. You should probably put new kingpin bushings and springs in. Don't know what condition yours in, but that one is a must. U-bolts, springs plates and studs and you should be good to go. Also will need some steering correction. Good luck. /forums/images/graemlins/thumb.gif
you should know my address so that you can send them to me. Yea make sure to replace trhings now when its not under the truck. Its alot easier to do it now then later.
Nick
the 60 has 20k on it and is good to go. Do need hubs thow. I have the k30 its conming from so lots of little stuff i need, i have.
mike
[ QUOTE ]
[/ QUOTE ]
I was just about to make a post about that. I thought my front end looked a bit higher after I put my 60 in yesterday, but I thought maybe it was my imagination. /forums/images/graemlins/smirk.gif
