So I’m getting antsy.
I want to work on this so bad but don’t have the time or concrete slab poured for it. I am limited to what I can do in the driveway because it’s sloped a lot. (Tough to tell by pictures, creeper is tough to use)
No, this isn't where I say it’s for sale
I would like to start collecting parts for a 6.2/6L80 swap. Even if it ends up with a 6.0, parts should be the same I think. What can I get started on now?
I have an ORD crossmember, that should help pan clearance. The engine will be out of a truck, will that pan be ok? In my ‘68 I had to use a different pan for the 5.3.
I’ve got DIY4x engine mounts coming, or at least the other half since I’ve got his comp mounts already.
I imagine I’ll need manifolds. I used some Trailblazer SS manifolds on the ‘68 that worked out nicely. I could do that again if they fit the 6.2. They have to be shorties because my exhaust runs around the front of the oil pan. Headers that go straight down would make this even better on the passenger side, though I’m not sure about the drivers side yet.
I have a VSS 241 but with a 27 spline. I am looking for a 32 spline input. I have an EFI blazer tank and TPI Camaro pump already. I run it at 43psi, here’s hoping it will do the 58 (IIRC) that’s needed. I need a digital dash, something like Autometer or FAST has.....but cheaper. OMG I’m not paying $2k+. Just need something that translates OBD info to a screen.
Once I have a concrete slab the 400sb/700r4/all FAST EFI stuff comes out and up for sale. That means the front end will be off, I can address my first wiring job’s shortcomings, rework wheel well openings, etc etc.
I’m excited to start but I’m not doing all that work AGAIN on dirt. Did that the first time and in a hurry. I’ve got a backyard, secure working area, knowledge, and more patience this time around.
