Seems like I read somewhere it's best to up the compression with aluminum heads, yes or no?
I think you could look at upping the compression even if sticking with the factory block and peanut ports. Those motors have really low compression.
Well, I'm not talking about the "more power" type of thing, just that I was thinking slightly more compression was needed to get the most out of the aluminum head. Not crazy compression, just that they'd be a waste on a naturally aspirated motor with 9:1 or less.
I've read the same thing. An iron head can make more power at same compression, so not increasing the compression would be a net loss unless upgrading pistons, etc to increase comp.
Don't just bump up compression just because you're going to run aluminum heads. Decide what cam you're going to run and pick the combustion chamber and piston size to get the compression the cam wants.
Thanks, that's the kind of advice I need.
But everything need is still in speculation until you really tear into it and see what the cylinder walls look like and all the bearings. But Comp Cam makes great cams for the BBC's in the form of the Extreme 4x4 flat tappet cam. Like I said I run one right now and ran one in my sbc as well. They were the second biggest one you could get. I'm switching to a Nitrous\Turbo\Blower cam this winter due to running a plate style nitrous kit now. But let use know what casting you have when ya tear it apart and we can consult after that....
