Best steering arm for the money Dana 60
74kay5
San Jose CA
Going crossover on the new Dana 60 and didn't even bother trying to convert the stock steering. I have a 2wd steering box mounted and will be going to the junk yard to try to find a tie rod and pitman arm that can be modified for my drag link. I've seen a lot of arms on the market and the springless seems to be the way to go. So far the PartsMike one looks like the best deal (comes with the 10 degree correction, the arp studs etc) for 139. It looks like you might have to taper the hole though. Anyone found a killer deal on an arm like that ready to bolt on and use with the large GM tapers?
Do you need a spacer to run that arm? The original arms I bought needed spacers, I didnt like that idea so I bought Sky arms (good stuff).
Been running an ORD arm for about 6 years now without any issues. The ORD arm accepts the large ES2010L, ES2010R ends.
Well it's back to the drawing board. The sky arm that I bought off another forum was lost somewhere between texas and california. The USPS box showed up empty, no arm no studs, no nothin. Just a box with a hole in it. Guy didn't buy insurance either.
:mad::mad::mad::mad:
If anyone knows where I can get another Sky high steer arm with studs and nuts for 85 shipped let me know.
He should refund your money. It was his fault the packaging was bad. The way I see it the seller is responsible for it until it's delivered in one piece.
He's going to give me a partial refund. Better than nothing. Your right though. The thing that pisses me off is that USPS insurance is what? 1-2 dollars??? Well worth it and cover's both parties.
