Started replacing battery cables. So far got the cable from battery to frame and battery to starter replaced. Also got an 0ga quick disconnect for the winch.
Did some fender trimming today. Going to be driving it an hour away and crawling and hopefully driving home tomorrow. Last trip before new gears and lockers.
Ordered diy4x comp motor mounts and energy suspension transmission mounts because I looked at those and those are blown also. I gotta quit this rock crawling stuff. It’s expensive haha.
I had 2 different Holley blue pumps on my old truck and they were brutally loud. You could somewhat here it over open headers. Maybe the red pumps are different.
Shop just called. Apparently I can’t count and I had a 3 pin carrier instead of a 4 pin so we gotta order a new carrier. Surprisingly it was actually a limited slip although it’s never worked. Tech said the clutches crumbled when he split it apart. Also need new inner axle seals on the front axle which I’m not surprised and one of the front calipers is grinding on a rotor so they are getting a new bracket to fix that. Always freaking something.
