Do the roll on bedliner - I used hurculiner through the entire truck (2 coats) , which I love
Let it try and then put the qucik roof on top.
Once done - install new carpet - this carpet form ebay does have the juke padding under it.
Some old pics - I did not put carpet or quick roof in the very back part - just the hurculiner. I did put a rubber bedliner mat (out of a ford truck) in the very back on top of the hurculiner. Didnt want carpet back there....dogs and junk stay back there...
no.. my floors were in good shape. you just have to get all that factory rubber coating off before you roll on the bedliner. I used a drill with wire wheel to take that stuff off and also knock out any surface rust.
Once done with that part - just vacume and then clean it good with some simple green or something, get out all the greese and junk.
Well I'm definitely going to coat the back, but putting carpet in the front seems like a cool idea... It'd be cool to make the front carpet removable and still have it all bedlined... What made you "just want to do the front?"
I have carpet also where the back seat passengers put there feet.... just the very back above the hump is not carpet.
I have all my junk back there, plus dogs, and whatever. Didn't want the carpet to always stay dirty..... just have a rubber mat on top of everything back there.
Makes the very back part much useful to me... no worries about messing it up.
Disagree. If u cut your carpet and pad properly there is NO need for adhesive. There are plenty of bolts to hold down the underlay. The factory glues only the pad down MAYBE.
