Blazer Bash 2020 last minute thrash
Too busy thrashing to get ready for KoH to worry about Blazer Bash right now...
okay so squeeze in a shakedown run ahead of time. Roger that.
I always tell guys. Flex it if you change the suspension. Otherwise DD it or drive the crap out of it around town. Getting some miles on it anywhere is better than nothing
In your case, you want that before the road trip. Make sure the shifters and hubs work (David had to rework his in Moab last year)
Definitely getting some of that in. Thrashing to get my truck ready for a little pre-trip up to Black Rock Mountain State park in two weeks. About 1,000 miles round trip. So that’ll give me a good idea of its driveability.
Also. At that beach trip I had both lockers locked and the 208 in 4Low because there was no way I was going to get stuck in front of a thousand other beach goers lol. So, so far, everything is going well.
Got about 300 miles on ol' Murphy. Found a few issues and need to finish up some stuff that @blazinzuk and I ran out of time to do at his shop.
Blazer Bash Thrash
  • June 14-20
  • Clean + setup Garage
  • Pull t-case w/adapter to reseal bolts into tcase
  • replace trans cooler lines
  • exhaust
  • finish rear bumper
  • bump stops
  • 21-27
  • Cage build week!
  • 28-July 4
  • shock mount reinforcement
  • traction bar
  • second crossmember
  • skid plate
  • oba setup
  • finish front bumper
  • re-do front seat brackets
  • change gear oil and upgrade diff covers
  • 5-11
  • patch floors and fuel fill cover
  • kilmat floor
  • pad floor
  • install carpet
  • door panels and dash pad
  • bed panels
  • 12-19
  • AC install - necessary
  • speakers - if budget is available
  • start prep for paint
  • 20-27
  • finish paint prep
  • paint
Glad to see I’m not the only one with a lengthy scheduled list...
BB20 Prep List
Completed:
  • Replace transmission lines
  • Install PS Cooler
  • Replace water pump
  • Install timing gears
  • Install Borgeson steering shaft
  • Reinstall muffler securely
  • Change 14bolt fluid post 500mi breakin
  • Install B52s/straighten frame/Dana 60
  • Install rear zero rates
  • Replace fuel filter
  • Install Serpentine belt system
  • Finish hydro-assist
  • Reseal P.Valve cover
  • Install rear calipers w/ P.Brake
  • Install P.Brake cables
  • Install longer brake lines
  • Adjust passenger parking brake
  • Bleed brakes
  • Replace tail pan & support
  • Replace body mounts
By End of June:
  • Build front and rear bumpers
  • Install rear AC
  • Install flooring
  • Replace window channels
  • Replace choke cable
  • Install 4 rear doors
  • Replace D.Quarter panel
  • Install anti-wrap bar
By End of July:
  • Install ORD Magnum 205
  • Replace rear main seal
  • Replace rocker panels
  • Build rear tire carrier
  • Build sliders
  • Install roof lights
  • Install headliner
  • Install interior leds
  • Install led park lights
  • Install led brake lights
By End of August
  • Extend bumpstops
  • Build sleeping/storage platforms
  • Placeholder for any unfinished projects
Maybes
  • Roof rack?
  • Off-road lights?
  • Winch?
  • Fridge?
