Been doing some stuff, some planned some not so much. Drove to Denver it died in a couple different intersections on Hampden in the hot sun a couple weeks ago. Guy helped me push it out of the intersection, I jumped in coasted 2 blocks down hill saw a shady spot, checked things out, fuel pump was working, as were injectors, no fire turned over well. Cooled down, started drove a couple miles died again on up hill in middle of 3 lanes, hit right lane and done. Coasted backwards onto the wide sidewalk, called Bent, then called a local tow to me who happened to be 5 minutes away and about to head home empty after dropping one off. It started again drove a couple miles and kaput, luckily there was a construction zone I coasted into. Got towed home.
So far I have found burned up rotor, questionable ignition module, (just a guess), 2 bad plug wires, one broken vacuum plug, another vacuum line was off but I may have done that replacing the rotor, module, and dizzy cap. I still have 4 more plugs and wires to change. Then a test drive 45 minutes each way and a cruise they have been doing.
