Blazerbash ‘22 yard sale
Driveshafts and parts... forged yokes. . all 1350 except for the BAMF. make an offer if you can use any of this.View attachment 422688
How tight is the High Angle megajoint thingy? Mine in the S-10 has a bit of slop in it and rebuilding it isn't exactly easy and parts are hard to come by. Heck that shaft looks like it would almost drop right into the S-10.
I have a rear bumper with a tire carrier off my first gen blazer. It was custom made, mostly 1/4" plate. Has a receiver hitch. It would need some cleaning up and a new plate made to hold the spare with whatever bolt pattern your wheel is. It got fairly rusty sitting in my back yard for years but it is still plenty solid. Not sure if it would fit any other years. It would depend on the frame width if it was the same as the first gen. I would take $50 for it and will haul it to Blazer Bash. Would like to see someone get some use out of it rather than rusting away in my yard.
Not new "tight" by any means, but not sloppy either. I maintained it regularly, it is a grease slingin pig ;)
I might be interested in this….what is an internal spider? I’m not familiar with the term?
Pickups on the bottom, in the corners, tied together then fed to the supply fitting on the tank. Check valves internal on the pickups, fuel supply at any angle as long as there's 5 gallons in the tank. Unless of course, you're upside down:haha:I ran that tank in my old tube buggy.
I’ll take it
PM me a price, I'm interested. I know they sling grease like crazy. Keeps the bottom of the S-10 from rusting.
Cut up wheel wells, maybe you want to cut your good ones? Use these instead. Free if someone speaks up now. Going in trash after BB. Can’t find my picture of them, kinda see in this poser pic. Cut for the shocks and along the cab.
12,000 lb steel winch line off my Warn. Good line, probably won’t go back and can’t store it if I did. Buy me a burger & fries from the Brewery.
Heck you can throw those on marketplace and ask $1000, just say typical rust for the year!
Wish I hadn’t cut them. Had no rust when I got the truck and zero battery damage :(
Got some speaker boxes also, free if someone speaks up. 5.5” and 6x9” not sure how well the speakers are but the boxes fit nice. Hurculiner on the outside, 3/4 MDF.
