Blazer's 68 Nova "Stephanie"
Do you know that your aluminum valve covers are too short, or do you assume they are too short?
Martin
Martin
The finned ones that I have hit the rocker arms when I set them on the head. The black ones that I also have are tall so they aren't an issue.
We need engine noises!
not vroom vroom either!
It ain't good for an engine to sit!
Been looking for some dollies to be able to move her around @AgDieseler has these I kind of like them Beck is a cool guy but they are a bit pricey IMO
I've used my HF ones to move a bunch of crap.
Lay a 2x4 chunk in the wheel dip, through a cut to size piece of plywood in the recess of the flat parts and you have flat dollies too.
Just looked and it looks like HF doesn't have the same ones anymore :dunno:
Mine are like this, but have a raised lip at each end making it perfect to lay the plywood in and it can't go anywhere
Get those pictured, do the 2x4/plywood thing I do, and bolt your own jack stands on them. Still cheap enough, and multi versatile
F that buy a plasma cutter and cut you own plates, get the HF casters ( same quality as linked) build your own. Can buy a nice plasma cutter for the price of 4 of those.
