So I got most of it all done, with some help from Riley.
Both rear fenders are on. Should have went with the not mashed version. The passenger side, because the tail light housing is bent, the fender mounted an inch or two longer then the drivers.
Roof is done if I get adventurous and grind down the welds may even look good.
taillights wired and working
Still need to paint it all. Mount the bed floor. Bleed the brakes, back ones basically not working right now.
Spent about an hour of wasted time trying to figure out the fuel filler hole. Ya no good do it will have just a whole for a bit.
Picture is before the passenger side was welded on.
Other then that seems to be pretty good.
One day I am going to not have to rebuild my truck the week before the Bash....... well probably not.
