Blazer's 85 Suburban "Twinkie"
I like mud when I'm in it, but regret the decision immediately after it stops flying.
I used to like mud until I lost an alternator on the way back home from a mud run and a a couple of days later pieces of my clutch pressure plate started falling off.
That was the last time I saw mud with my vehicles.
Amsoil makes a spray can of stuff they call "Mudslinger" that's supposed to make it easier to clean mud and dirt off. Haven't used it, but I thought it was interesting.
Levi shirley promotes that, but still ends up cleaning everything off with power washer. Not letting the mud completely dry is the key to easy cleanup. That being said, I hate mud.
Take a bottle of dawn dish soap, mix with about a gallon or 2 of water with it.
Soap up the truck really well. Let it dry.
Then go mudding.
Once your done you start spraying it down, it gets the soap activated and let's the mud just slide off. It works like a charm every time.
I used to do this, hell I would even just dump the soap on my truck after I "washed" it.
Mud is all we got here :frown
And, if you roll into a carwash bay covered in mud, they'll kick you out.
That said.... You'll just have to add more power to Twinkie:burnout: or get started on that mud truck :popcorn:
Spring mount is broken on the bottom of the gusset too. Definitely time for links :D
