Looking for opinions on break in oil. Brand new build with a hydraulic roller cam and roller lifters. Builder recommended something with high zinc and no synthetic to start. 10w-30.
That’s what we used and dad still uses on his bronco.I’ve used lots of vr1 valvoline. And other than the two GM crates I’m currently cussing at for rings, no issues
I attribute both of those to poor QC by GM on the rings
No concerns. And the super high zinc paranoia I wouldn’t buy intoThat’s what we used and dad still uses on his bronco.
Yes its possible to get a good ring seat without breakin oil, but you increase your chances the piston rings are breaking in correctly with the proper breakin oil and proper engine load for breakin. Watch the videos above from the Lake Speed Jr, the guy is a motorsports oil specialist that works with Total Seal that has tested this stuff for a living. There a lot of opinions on the subject, but when it comes down to the facts I trust him. There is a difference in the additives and base oils in the breakin oil for a reason.I'm sure this is after the fact but do NOT use "break-in" oils EVER, liquid garbage and a complete farce ! This crap has the lowest PSI rating of nearly any oil on the market and that's a fact. I also love the guy that says "no synthetic oil during break-in" total bullshit. Skip White uses Schaeffer Micron Moly full synthetic in new builds getting dyno run that says a lot... Don't waste your hard earned money, use your flavor of full synthetic from first start up till you blow it up and sleep well, my personal favorite is Amsoil Z-Rod for any non daily driver read up on it good stuff...
There is alot more opinion than science for break in oil in my view.
I have broken in plenty of cams back in the day with cheap dinosaur-bone oil with no attention paid to zinc what so ever. I think the issue lies in the higher spring pressure applications that tend to be in your performance builds. I was/am poor so all my builds are definitely not performance lol.
Typically don’t use synthetic on break in due to the rings
