Break in oil
Since you mentioned that it's a roller cam, just run whatever you plan on running in it. No need for fancy high zinc anything in that application. You're not breaking the cam in so to the guy that said "driven", he's right. Start it and drive it. Change it a little earlier than you would normally and then resume normal intervals after that.
I have broken in plenty of cams back in the day with cheap dinosaur-bone oil with no attention paid to zinc what so ever. I think the issue lies in the higher spring pressure applications that tend to be in your performance builds. I was/am poor so all my builds are definitely not performance lol.
Even so, for a roller motor, you're good with anything. Synthetic, conventional, whatever.
I was discussing the flat tappet engine issues with my local engine builder and how the new crop of lifters are garbage and he told me he never has any issues but he breaks them in with lighter springs.
It makes sense and I don't know if any of you does that but I think it's a great idea
I really don't cam anything that needs more than stock pressure springs.
But I haven't broken in a new cam and lifers in years
At one time I had 1.6 ratio rockers on this engine. Forget why I switched back to 1.5
Once you go roller...you can get way more valve lift with less duration than a flat tappet.
This is a bigger benefit than the reduced friction people talk about. For crying out loud, we run big transmissions, T-cases, and axles, giant tires and heavy trucks. We don't have the right to say that friction matters.
I change at 100, then 500 then run it to regular changes.
Changing at 100 gets most of the breakin wear, minute pieces of lint, dust, and break in lube trapped in the filter. Use more break in oil!
500 mi gets the finer particles of break in wear, and parts should be fully mated. Switch to your engines required long term oil after that.
Sounds reasonable.
I need to drive more. 20 miles a week is going to take a while to break in.
Why don't you get on the freeway half an hour each way 80 miles in one day.
Change the oil and filter, go one hour each way 150 per day.
3 days change the oil you're done.
For the record I did mine in 2 days.
First day 100.
Second day 300 and I called it good
Much as I would love to have that much spare time in my life, it’s not a thing. Kids, sports, chores, work, doesn’t leave a lot of time for random hour long trips.
yeah and you still need to do some ring seating, gradual accel-cost-accel, I thought Texas was full of back roads ?
Get that crap out of it YESTERDAY dump in whatever you plan on using, I'm an Amsoil guy, and drive it like you stole it !!!
Parts of it. There’s a couple around here I may hit up this weekend.
Why?
I feel all of this pain
Why?
BP Driven is widely acclaimed as one of the best products on the market at the moment, including by lake speed Jr
Google it
What’s the word on the first oil change with this stuff? Wait 400 miles or change it sooner?
Actually I change it quite fast, basically after one dyno session or a maybe 1 or 2 quick street drives assuming you put some cylinder pressure in there to seat in the rings and didn't baby it. Sometimes I change it before the dyno session is even over if I will be adding nitrous or something toward the end.
The sooner you seat the rings the better, do not wait. If you haven't seated the rings in yet, do it the next drive, then change it to whatever you are running in the long term.
Don't use modern emissions oil in it, get some racing oil or something. I use Mobil 1 15W-50, or Lucas Racing Full Synthetic. Don't use Mobil 1 5W-30 or something, its not the same additives as the 15W-50.
If you want some 10W-30 or 40 depending on what they set your bearing clearance at, I can send you some Lucas Racing Full Synthetic if you need.
Being in TX I would just run the 50 wait and see if your oil pressure isn't too high.
