Actually I change it quite fast, basically after one dyno session or a maybe 1 or 2 quick street drives assuming you put some cylinder pressure in there to seat in the rings and didn't baby it. Sometimes I change it before the dyno session is even over if I will be adding nitrous or something toward the end.
The sooner you seat the rings the better, do not wait. If you haven't seated the rings in yet, do it the next drive, then change it to whatever you are running in the long term.
Don't use modern emissions oil in it, get some racing oil or something. I use Mobil 1 15W-50, or Lucas Racing Full Synthetic. Don't use Mobil 1 5W-30 or something, its not the same additives as the 15W-50.
If you want some 10W-30 or 40 depending on what they set your bearing clearance at, I can send you some Lucas Racing Full Synthetic if you need.
Being in TX I would just run the 50 wait and see if your oil pressure isn't too high.
