Make sure you get the spring plates too, they are different because of axle tube diameter.
4X4HIGH said:Make sure you get the spring plates too, they are different because of axle tube diameter.
blazinzuk said:Heres a bit of a different angle on things Av. Just gear your rear 10 b then when you have time or money get your 14b gear it to match your 10b gears and switch the 10 b gears to the front and put the 8 lug outers on your front axle then. then you would have 4.88 or 5.13 gears on 3/4 ton axles and as long as you leave your 10b up front open it should live a long happy life. If you decide to do this and are worried about breaking your 10b let me know I happen to have a few extra 10b lying around
