Re: Broke 60 shaft, water in the hubs, brake pads falling apart need major
Hey Brandon....Have you pulled the diff cover to get a look at the gear lube in there? Considering all the crud inside your hubs etc, it might be a good idea to pop the cover off and have a look. There are the two inner axle seals just outboard of the carrier. Pulling axles in and out often is hard on those seals, crud can be pushed from inside the tube past the seal and into the diff. If everything is good, you'd be out some gear lube and a new gasket/RTV....If it's not good, well, you'd still have to get that stuff, plus the seals. And alot more time to replace the seals since the carrier has to come out, but atleast you'd know everything is ok. /forums/images/graemlins/smile.gif
