Broken 10 bolt
royjones
Trucker upper
somewhere close to ya
Hey guys I have broken my 10 bolt in my 86 k5. So i have the bright idea to use a 12 bolt that I got off a scraped truck. Everything worked fine til i got to the drive shaft . ;[ the 10 bolt ujoint is bigger. What would you guys do?. Is there a yoke. that i can buy ? do i have a custom driveshaft made.
most guys just swap the yoke from 1 to other axle. same spine count.
just dont over tighten of you will over crush the crush sleave. but best to install new .
Napa sells conversion u joints that have the size of the yoke on one side and the size of the shaft on the other. That's the easiest way I know of.
Oh wow duh huh I didn't think of swapping the yoke. from the 10 bolt. The u joint i think is 3-3130 if all else fails lol thanks guy's
Seals are cheap, and probably need replacing anyway.
This topic has come up here before and somebody did post the # for the seal, so it does exist. The smaller sized U-joint is really no prize, but I guess you can just worry about the yoke swap/upgrade if you ever break that conversion joint.
