Jason4x4
I like the tags on this thread.
I always thought that lean was from bent axle housings?
well in 5 years when he finally gets the thing put back together then takes it out once then comes home and dis assembles it, i'm sure we'll get a review.I am now officially "ULTRA SUBSCRIBED" to this thread!!
ORIs seem like the shiznit in a lot of ways, so I'll be curious to see how they stand up to the Shawn-style abuse, jumping videos and general tom-foolery that you'll be dishing out.
well in 5 years when he finally gets the thing put back together then takes it out once then comes home and dis assembles it, i'm sure we'll get a review.![]()
I think it be better to upgrade the t-case to 32 spline rather than downgrade the trans to 27 spline. I am looking forward to seeing your next project. Always fun stuff.
I think he'll be OK. The 27 spline GM shaft is only .040" smaller than the 23 spline Dodge shaft (the Dodge shaft uses larger splines which is why it has fewer teeth), which was used in Dodge's autos behind the Cummins in the 90's. Nobody ever really broke them until they started bombing the engines... and then they usually blew up something else in the trans first![]()
Good to know, but im sure as hell going to put it to the test and find out.
One thing pisses me off to death though.
I got my first trans built when I was 17, I beat it, put 4-5 big blocks, couple small blocks in front of it. Over heated it, blew up a few of those motors, blew up the chain on the 203, trashed the cab, ran it low way to many times, dropped it on the ground during install.
Later sold it to a buddy for cheap.
Im now 26.. and he is still running that same damn th-400.
Should have kept that one, I seriously have long since lost count in how many transmissions I have put in 4x4s over the last 10 years.![]()
You got a core yet? Is J gonna build it? 20 bucks says you blow it up within 10 outings![]()
doesn't matter since you are changing the output anyway
