Those are nice but for 150 more I got the Reid Knuckles but those look legit !Another option for beefed up knuckles is Solid Axle Industries. You can sometimes find them for a couple hundred bucks cheaper than the Reid knuckles. They're nodular iron, accept all the standard kingpin parts, are "made with extra material and webbing in critical areas", and the tops are keyed so it takes the stress from turning off the studs (requires their steering arms or ones from Artec) or you can order them without the key and run any of the common aftermarket steering arms. I ran across them when looking at options for my Ford 60 and they seem to have tons of positive feedback on Pirate and other forums.
https://www.solidaxle.com/productcart/pc/viewPrd.asp?idproduct=37&idcategory=10
What did you torque the bearing caps to
I do boats and hoes baby ! Lmfao !
I think they’re bad A$$ can’t wait to try it out !Thread hijack in a slightly different flavor!
Was just doing some winter maintenance tonight and thought I'd join in! Extremely happy with ARB's, that's all I'd go with now-a-days.
You won't be disappointed by the springs![]()
what do you mean I got umm front and rear !
I noticed yours was different when did you buy it ?@1977k5
what style arb is better ? early like mine or late like his and yours ?
for the dana style fronts .
no real test yet . . . long story .
Ok so back to suspension ... as stated before I’m gonna go high steer crossover to do so I need .thanks buddy for the info .![]()
