I plan to get about 625 hp and close to 680 tq. out of my 454 build, naturally aspirated, thats not hard to do. about 10:1 compression on 91 octane pump gas. will be running Al. heads too.
my plan is .100 over,
did you mean .010 over ?
I wouldn't bore a 454 more than .060 over without having the block sonic tested first...
big blocks don't have the thickest cylinder walls stock..
Now if you plan on using an aftermarket block like a Brodix or Dart, then .125 over isn't a problem.. of course if you're going aftermarket, then hell, go for a 4.5 or 5.0 inch cylinder spaced block and build a 632 ci
stump puller !
Slippery slopes them BBC's are!!
Or just dial up Sonny's and have them put one of these in a crate and ship it to you!
https://www.sonnysracingengines.com/engines/drag-racing-engines/sar-1005-2100-hp
THE FIRST V8 ENGINE OVER 1000 CU. IN. ENGINE HERE AT SONNY'S! THIS MONSTER MAKES OVER 2100 HP,and over 1550 Ft. Lbs of Torque, AND YES IT'S NATURALLY ASPIRATED !!!! NICKNAMED " THE GODFATHER" Because this is the Big Daddy of all engines, and who else could produce such an Amazing Engine, nobody but Sonny Leonard Himself!
2100+
1550
Complete and Dyno Tested
Price: $109,000.00
Link didn't work, but I have read a little about building a block with peanut port heads.Found plenty of stuff in this thread:
http://garage.grumpysperformance.co...-building-a-peanut-port-big-block-combo.2900/
Aluminum heads dissipate more heat than iron. An iron head, identical to aluminum in every other respect will make more power. But with higher compression, the iron head will usually start to encounter detonation issuesI would like to know how you think aluminum heads will cost you power based on compression ratio.
I think you could get a L29. @ZooMad75 still has one under a bench??Link didn't work, but I have read a little about building a block with peanut port heads.
In order to get compression up, won't I need to make changes to the bottom end?
I was thinking this morning about the question of building for torque. I feel like the 380 or so torques it has now is sufficient, it's the horsepower that's lacking. I think anything is increasing the horsepower is going to increase the torque plenty enough. I'm not really thinking about doing this to fill a practical need (although it would be nice to have an easier time pulling the camper), I just want to have a badass motor once in my life.
Now to completely go against what I was just saying about building for torque, I do admit the idea of a stroker motor would be cool. I saw the crank @beags86 posted in another engine build discussion and it wasn't that expensive. I was kinda thinking maybe that would work if I could find a set of better factory heads and a roller cam and that would make some good power without getting super expensive.
I'm not sure what you are telling me? I asked you to tell me how an aluminum head will cost power.Aluminum heads dissipate more heat than iron. An iron head, identical to aluminum in every other respect will make more power. But with higher compression, the iron head will usually start to encounter detonation issues
If you have low compression, the aluminum head will dissipate MORE heat. Heat is power. In a low compression motor iron head will make more power. Its simple physics. Most of the time it doesnt come up, because usually we build for more power, and use more compression. The aluminum head and its dissipation of heat is what allows the higher compression. So in this particular engine, at 7.9:1 cr, an aluminum head will COST powerI'm not sure what you are telling me? I asked you to tell me how an aluminum head will cost power.
I disagree with that. While the cooling effect will help with high heat for compression is won't hurt power in a lower compression engine.If you have low compression, the aluminum head will dissipate MORE heat. Heat is power. In a low compression motor iron head will make more power. Its simple physics. Most of the time it doesnt come up, because usually we build for more power, and use more compression. The aluminum head and its dissipation of heat is what allows the higher compression. So in this particular engine, at 7.9:1 cr, an aluminum head will COST power
I do have a L29 currently with no plans. Might be willing to part with it as it will help fund the 8.1/4500 swap. @mrk5 if you are inclined, let me know.I think you could get a L29. @ZooMad75 still has one under a bench??
Stroke it to 489, bump the compression, port & polish the heads, and slap a new cam in and make 500 hp.
Or I would take your block, bore and stroke to 496, put some good aluminum oval ports, with a roller cam and you would be set to.
Not sure what you want to spend. The
l29 would probably be cheaper. I can pm you a guy in Arvada that will do a good job on a port and Polish, he did the heads on my 406.
We can disagree. I dont have a problem with that at all. I think its good to share our knowledge/ opinionsI disagree with that. While the cooling effect will help with high heat for compression is won't hurt power in a lower compression engine.
Heat isn't power. Power is compression, fuel, air and spark. Heat is a byproduct of the engine running. And everything you do to an engines, cooling system is fighting engine heat
Exactly. The average guy throwing something together to haul his boat/camper/whatever would be fine with peanuts on a good combination. This isn't SBC stuff. Big block heads work.
I've got a set. Hopefully good ones, but I will keep that in mind. I'll take all the 781s, and Quadrajets you can send me.
Does it have the EFI too?I do have a L29 currently with no plans. Might be willing to part with it as it will help fund the 8.1/4500 swap. @mrk5 if you are inclined, let me know.
Yes they make gen vi stroker cranks.Does it have the EFI too?
Interesting thought, can you put a stroker crank in an L29?
Technically 800....If I gotta drop $1500 to stroke it, it would nice to keep the EFI I have now.
