Building a 500hp 454
mrk5
The Sticker Guy
Moderator
Vendor
Author
Northern Colorado
I've been thinking a lot lately that I've never owned, or even driven, a "high" horsepower motor. Closest would probably be the 383 in our 71 cuda (don't own anymore) or the 08 2500HD 6.0L company truck that are both around 350hp. So I've kinda made it a goal to build a 500hp motor.
Bearing in mind I don't know a lot about building motors. In the past I've taken them to a machine shop and had them rebuilt with a mild cam. I know very little about big block engines.
I'm working under the premise that the Sniper I'm running now will support up to 650hp as advertised so nothing new is needed there.
Some info on the engine I have now. It's a 454 with peanut port heads. It is a 4-bolt main block for what that's worth. It's a rebuilt Jasper engine with unknown miles, I would guess between 10K and 20K. The block is very clean and the cylinder walls still had good crosshatching. To me the cam looked to have more wear than anything else in the motor. We did a compression test and all the cylinders were good and consistent. We did not do a leak down test.
In the interest of budget, how realistic would it be to just throw a set of aluminum heads and a roller cam in this block and run it? Would the low compression kill most of the potential horsepower gains? Would the heads raise compression some?
Thoughts?
I'm guessing flat tops? I believe large ovals off a 396 can get compression up to a good place, but I forget the specifics now.
I'm sure someone knowing more will chime in soon, also the Chevelles.com forum has a ton of good big block info.
What are your plans for this engine?
It would just live in my crew cab which is my wheeling rig. Also use it to tow our camper.
A 500 horse big-block is so easy these days.
Invest in a good set of heads. They will cost you... About 2500-3k...and a good roller cam....about 3-4 hundred... Headers and intake and you should be there... You low compression bottom end will probably hurt you a bit....
I have thought a turbo or supercharger would be great for power due to altitude. However adding a turbo is beyond my skill set and a supercharger is beyond my wallet.
Keep in mind everything is a compromise
I’d see if Zoo can find you an 8.1
Then your limited by that stupid head bolt design. Pull your 454 build a 496 with real heads and cam and your set. That's what I'm doing with my 454 for my 76 stepper. Unfortunately I haven't done anything with in 3 years due to having a flake for an employer during that timeframe. Now I work for the biggest construction company in world I should be able to to get back on track.
More the aspect he really wants the tork
But yes. A good set of heads does wonders
With it being a rebuilt engine have you see the lifter valley? Reason I ask is if it has built in provisions for a roller cam. Not a big deal if it doesn't, but it's a little cheaper cam wise if it does. Budget wise, look for a good set of used l29 heads. They're iron, but have really good flow rates and can often be had for a lot cheaper than aftermarket aluminum. Maybe find a good running l29 and swap cam, intake for your sniper, and sell your original block to recoup some cost)
I was looking at those. Of the 3, only the first one would work for my engine. I had noticed in the description on their website they said the HP rating was based on 9.6:1 compression ratio which is what prompted my question about using the bottom end I have now.
A set of domed pistons with a dome height of 0.230 (or 22cc) should get you in the 9:1 compression range with a set of 118cc open chamber heads
What I said would give you about 600ft lbs. And he's got the sniper so no messing with the 8.1 harness, ecu, etc. Different strokes I guess.
