Bunny
85 k5
Broke. Thankfully late in the day I tried some dumbass trail. Broke the left front shaft and bent the shit out of the frame. Like ruint.
The electric fans were hitting the water pump the frame was flexed so bad.
Time to swap parts to another rig. I actually found out yesterday that my frame has a bend in it too in the same spot. My plan is to wheel it a while longer and then swap my parts to another rig. My only thought is next one might be a GMT400 instead of a square. We shall see
I think you're right. I definitely have seen this day coming. Yesterday while on the trail seeing it bent I was sure it was smoked. Well after getting it back on flat ground and going over it a little Ryan and I both think that I could and should probably just engine cage it like I wanted to and wheel another couple times and see.
So you’re both saying I should engine cage tied into the main cage before I wheel it too much more?
Wolf Caves is a great place to go wheel. Also have to say this is a good group to wheel with. We all pretty much hung with each other on all the obstacles. Alot of wheeling in one day.
The bobbed scrambler ripped the box off the frame about 5 pm. The 6.2 short bed had lift pump problems early on so it got left back. Then my problems near sundown.
The pictures with the wolf caves stamp were taken by the park owner. This was a benefit weekend and new trail to help a kid get an offroad wheelchair. Supposedly the first time it was open or something.
Thanks man! Thats the left turn that did me in.
Yeah. Essentially next door. Under 5 minutes to each entrance.
I was changing oil on a leaf sprung super duty on sat and glanced at the frame and they sleeve them in that area for about 18".
Nice, I was a little worried since I hadn't seen anything posted about her.
