I'm mig welding a patch panel using 023 wire and gas. What should be the panel gap size between the two metals?
mig weld, just using quick hits with the welder. like little spot weldsMinimal…. Are you just gonna stitch weld it in?
rockersSmall tacks, never one after the next. You don't want heat to build in one area, it will cause the panel to warp. Get your corners tacked, then work the tacks back and forth along your line. Same goes when you grind the tacks down, don't say in one place for to long.
What section is getting grafted in?
