Haven't we seen the blue and silver one before?
They are both good looking examples of k5 blazer. Square body.
I did just join, glad i did. I have been wanting a k5 blazer and now have the ability to get it. Also, if anyone sees or knows of any for sale in any part of the country I'm happy to have a link for it.I noticed you just joined. Hello and welcome to the best GM 4x4 site on the interwebz!
I'm not sure as I have never posted on here before but it is from a national sales place. Hopefully I find the one that fits best for me.Haven't we seen the blue and silver one before?
So they stopped making the full size blazer in 1991, so the Suburban will be more common leading up to that period, and then only Suburbans and pickups
This also marked the end years of GM using a solid front axle
Then there the Blazer looking Tahoe
Pretty sure they continued using Blazer badge into the GMT400 for a few years, and was still a 2 door. When GM started using Tahoe/Yukon badge is when it gets confusing, because they are all 4 doors, and the suburban model is longer. Sometimes the Suburban was called Tahoe xlt, 7-8 passengers.
1991 saw the K5 designation disappear, or maybe is was when they changed to V/R, Are we confusing you @Irishmic. We don't mean to, ask any question you like we will answer, as best we can.
OBS and GMT400 are same truck, just different nomenclature. Didn't what vid, but the trucks changed in 1987.5 and were 1988 model year. The Blazers and Burbs didn't change to GMT400 till 1991. I want to say some crew cab duallies too, but don't have a solid memory on that.
I guess the other question I have is engine upgrade. Most I see are 5.7 v-8 but want a stroker kit on whatever engine is in it. Does going up to a 383 or even a 408 turn out good for k5? Of course it all depends on what the individual wants, I won't be doing any crazy off road, mostly on street. But as just a basic thought on the engine, value in each for the blazer and drawbacks some may know of. I am not about to do this work myself so it will be done by a professional company that does this type of work.
Yes I think someone else a year or so ago was looking at that k5.I'm not sure as I have never posted on here before but it is from a national sales place. Hopefully I find the one that fits best for me.
I'm going to be getting one that is road ready and is in good working condition. As far as mileage I'm not concerned. And yes there are many choices for the chevy, I was leaning to diesel but have since come back to gasoline.Cool thing about chevys, there is a crap load of engine choices
There's straight sixes, v-6s, v-8s,.
The v-8s come in small block, big block, and diesel.
I would say the 350 (5.7) is most common. Which is great, as there has been and most likely will continue to be tons of aftermarket power parts available for it. A well built reliable 350 can make 350÷ horsepower all day long, no problem.
Great for a daily driver and off roading.
If you get one that needs a new motor you can get one already assembled, dyno tested ready to go.
Are you mechanically inclined or will you have a shop do the work?
Don't know what you expect as far as mileage, the 79 I just bought gets 10.5 mpg on average.
It has 4.10 gears (High rpm's) and a 400 small block. It does not have an overdrive gear.
You will most likely get more confused before it makes sense. Stay away from dealers, buy from private individuals when possible.
Well I like how you think. Might as well go big if you're are going. Good to hear from someone with a larger motor. I'm still looking and I guess it all depends on what come along with it. Cn it be built up or like you said just start all over with big.Well, if $$$ is no object...lol
If I was building one, I'd go with a built 400 (small block) or a warmed over 454 (big block).
The big block produces so much torque naturally it doesn't take much to wake it up.
Never had a 400 before this one, it does good for a paltry 7.2 compression ratio. Very torquey for its era. I drove it from CA to NC, never lacked for power. Even in the mountains.
