No drill or easy out .
Scuff the broken nub and plug weld the nut on . Let cool . Heat area around and turn out .
Gotten them 4 thread in before .Even when it's that far sub surface?
.I modified my stock engine cross member and used stock motor mounts with the $60 realignment plates.I'm embarking on my first ls swap very soon. If this is in the wrong place I'm sure a mod will move it lol.
I'm not really calling it a build, but more of an experiment and upgrade.
I plan to install an LQ4/4l80e combo from a van into my 85 C30 dually. Currently it has an all stock 454/sm465 setup.
I've saved and made shortcuts to a few threads on here that I knew were informative over the years. And I'll be re-reading most of them starting yesterday.
I'm currently in the parts and info stage. But will be progressing quickly once started.
What I have:
The truck,
The engine/trans combo,
The tools that I'll need (except maybe some LS specific ones),
And a space to do it.
What I know Ill need:
Exhaust manifolds that fit the truck. (Thinking of just going headers, but would rather save $$$ if there's a cheaper option).
Mounts, or adapter plates. (Might modify the stock ones that came on the engine ....?
PCM flashed for vats removal and whatever else needs done in it,
A shifter,
And I need to modify the harness.
You are being paranoid. My dingo mounts never moved. I'm pretty sure I was rough on it too. A little blue loctite on the bolts and they aren't going anywhere. Keep in mind the trans mount is part of the system. So as long as you don't tear the trans mount the engine isn't going to move front to back. It's a good reason why they don't move once bolted in and everything is locked down.On another note... In order to make my engine cradle/cart/stand thing, work with normal chevy engine mounts...... I'll have to get the mounts I need before I ever take my BB out of the truck.
That leaves me short on parts..
So I may end of with the dirty dingos, even though I'm not sold on them.
I need this part of the mounts.
Bottom pic is what I do have.
Every place I've found them wants about $30 each. And it seems like maybe there's 2 different styles. But all I can find are SMALL block ones.
So given the dingos have that part built in and are $110. And Kurt's plates are $75, plus $60 for these,... Add shipping (dingos I can get from Amazon), and the dingos end up much cheaper and simpler... Still just don't like the slot design deal though.
If they were being mounted to a flat surface it wouldn't bother me. But being mounted to raised bumps with a small surface ,then tightening down to them. It seems like the small area could work its way into the groove enough to loosen up over time.
Maybe I'm being stupid and paranoid, wouldn't be the first time, but I like things to be over engineered.
maybe supposed to be 1200.
