Calling Rootbreaker??
BILTIT
Lloydminster,SK
Rootbreaker, how do you like your crossover steering? I am considering it but not sure if it is worth the $$ for my DD/Tow/offroad truck. I can definatly notice the bumpsteer.
So you have detroits front and rear? I am contemplating one for the front since i will be swapping to a D60 shortly.
What are you running for tires? 39'' GH's? Just curious if your 4.56's are enough gear. I am switching to 4.56's with 36'' tires. I will also be putting in a 400P for the torque factor.
im here in and out..... so much going on all the time....
anyway...
lemme see what I can answer...
well lets say I was worried about the extra cost.. but tell you what... LOVE IT
my truck turns sooo much better now...
also consider this... if you have the traditional steering (this is why I upgraded ..as this happened to me...)
you go down a windy steep hilly trail.... as your left tire (think that was the one) droops as there is a hole there.. your steering wheel will turn on you even though you are going straight... well at the time to turn.. im already locked on the steering wheel... cant turn the way I need to because the drooped tire has taken all the steering out...
ok also my power steering belt was loose but you can see how well it turns here...
http://www.supermotors.net/getfile/214996/fullsize/xoversteer.wmv
I love my front detroit... and yes I would do it again.. although people say on rocks detroits can be a pain... but in the mud and sand.. I LOVE MINE!!!! :wink1:
I started out with the smc465 and stock 4.56's with 33's.... real stump puller... went to 40" ground hawgs... hawgs run small... from denman they say a 40" hawg on a 9.75" wide rim is 39" well I put mine on 12" wide rims to get the height down some more... so I am at 38.8 but I needed that to pass inspection....
there are always delemas... people say gh suck.. well they wear like iron... are not great on rocks... second best to boggers in the mud and sand... and dont wear out to the pits like boggers....
I myself and 2 other people I know love GH and will never go with anything else....
with detroit front and rear.. I dont have to throttle like everyone else.. but get to use finess to get through what I need to....
YIPES!!!! 400hp NICE...
I took a sloppy 1991 caprice police 350 (told it was high hp and bought it when the internet was not like it is today)
well it is a measly 195hp and 295 lb ft torque.. but at least a roller...
it is the L05 block...
I added 1996 tahoe vortec heads
comp cams extreme 4x4 cam (smallest as I wanted power at idle) so it is .458" lift
weiand power plus+ dual plane intake
full tube headers
holley truck avenger 670cfm carb with .35" discharge nozzles and biggest accelerator pump.
I have not got to dyno the truck yet but this summer I want to... im hoping to be about 300-325hp and 295-330 lb ft torque...
now this post is getting long so I appologize and bear with me...
I just put my truck on the road in 2005 as it was off the road since 1997. before the motor mods I was not impressed with the trucks power... I did not get stuck AT ALL but I was not impressed.... I did the motor mods and still not impressed...
I just added a msd 6al with built in rev limiter and timing control module.
Well now we are setting my timing and realized something... my timing is off...
so we pulled the plug and went to top dead center, rotor facing #1... well it is still not right.. so we pulled every plug off and moved them over counter clockwise... then rotated the distributor clockwise (lost yet :haha:)
and now the timing is set.. the problem I was having is I was hitting the intake and couldnt turn the distributor enough.....
so hopefully with this new found timing and all im hoping to be more pleased with the power...
the 4.56 are enough with the smc465 to spin these hawgs with EASE and retarded timing!!!!!!! :bow:
any other q's just ask.... I have started posting now and then.... it is cold out so things slow down a bit... :crazy:
hmmm, I also have the same Weiand intake and my distributor hits the it too, and i can't advance the timing enough to where I want it.
So I am confused how did you overcome the intake?
You need to pull the distributer and install it one tooth over, this will give you more room to advance the dizzy.
Thanks for the answers. I think i will go crossover, maybe not right away but on the list. That vid helped. I have a line on a powertrax for the front 60 for 200 bucks so i will go that route for now i think.
That was not 400HP but a 400 pontiac motor. It should be around 350-400hp though. I am going for 450-500ft-lbs of torque. It will also be nice to have spare parts for the race car when i tow it down to the track (it has a 455 pontiac).
I am starting to wonder if the 4.56's will be too much with the 36'ers. I have 4.10's and found them to be lacking with the 350 in there and 35's but i think i just need more power.
The 60 is 4.56 so i was going to swap the rear up but i may swap the 60 to a 4.10 instead.
well since the timing was turned all the way and im hitting the intake...
I moved the wires all over 1 spot...
I could pull the dist and move the teeth over but my dist is up against the firewall and you aint getting it out......
by moving the wires over 1 counter clockwise and turning the distributor clockwise all the way I basically gained a new rotation of the distributor....
trust me it works... but I could redo the distributor gear.... but id have to yank the motor to do it!!!!!!!!!!!!!!!!!!1 :doah:
Thats kinda strange... Is your engine set back a few inches? I can pull my dissy with no problems. I need to play with my timing more because I am now getting some pinging...
tcase drop made the engine sit on an angle.... since I did not lower the engine too.... then the engine angles right onto the firewall.... there is some room.. but not easy...!!!
the weirder part is the fact that we did get top dead center, rotor facing #1 and the line on the harmonic balancer was in the right spot (my father said it was :haha:)
